Hello guys, I have been tryin to find some info on changing my sled to fox shocks, like the fox float 2 seems a bit more in my price range I see some set of fox float evols on ebay for pretty descent prices and some are listed to be Arctic Cat shock from 17in ctc to 17.5 ctc
Would these shocks work on my sled? one thing to keep in mind is my sled has Zbros 36inch front end, do I need a shorter shock now, I know the Walker evans shocks on my sled were sent in and revalved with dual rate spring for the 36 front end. would I have to do the same with another set of fox shocks? I'm not sure if the 36inch front end required a shorter shock or if the arms have relocate built in.
Would the Arctic cat float shocks work like the bolts size is the same and interchange like that would ya know? and does the shock need new internal parts for the difference from an M series Cat to a Pro Rmk?
One more thing, I really like the Evol shocks but would the floats 2 be good enough also?
Any info or suggestions would be appreciated
Thanks, Wildcard
Thanks, Wildcard
