Need a replacement skid for a 14 pro 155 seems like I'm having more luck finding axys take out skid than pro. I found couple without shocks fairly reasonable, my shocks are good but the rear axys shock is longer so I'm wondering if I put the pro rear arm on and use both pro shocks will it fit? The part numbers for scissor are same, rear arm is different which I figured, rails are also different part number, being scissor is same I would guess if rear axle to scissor mount is same dimension that everything would work...
