Thanks Silber Turbos
C
Cconmichael
New member
Oct 30, 2011
19
3
3
Iowa
I just wanted to give a shout out to Corey Boston and Silber Turbos. I just recently purchased their 2014 kit with the ECU reflash and oil less turbo (at an amazing price). I had a trip planned 1 week from the day I purchased the kit and was worried about getting the kit in time for the trip. Corey was amazing to work with, he got me the kit in 2 days and helped me throughout the install. The kit was super easy to install with a very clean finish. At 11 psi the sled absolutely rips and is 100% pull and go. If your in the turbo market I would highly recommend the 2014 Silber kit with ECU reflash. Thanks again.
wellfed777
2,226
412
83
Oregon
good in silber and Corey
what clutching setup , boost #s and fuel did you end up at
thanks
A
aj1180
Dec 17, 2009
114
waukon ia
I have a sled built by Cory and it rips. Absolutely pull and go. I'd buy from him again no questions asked.
skibreeze
10,463
3,477
Colorado Springs
It is almost always a sled issue, maintenance or install. I have had many issues during the year that come from both of these.
I've had these issues:
Throttle safety switch
Reeds
broken primary springs
Missing/ torn O rings on the bolts holding the alum plate to the throttle body.
Loose silicone hoses
Running a BD EBC from the plug by the headlights and realized that it was pulling too much juice and causing it to run like crap.
I'll admit that I was blaming the kit at times, but it was always something else causing my issues in the end.
