T
Hello, ive got a 2009 iqr chassis with a 2012 800 cfi engine in it. I recently installed a 2013 silber turbo/bullydog in it. My question is will the 10%ethanol/prem resistor still work even though i had to replace the 2012 ecu with a 2013 ecu to make the turbo work with the bully dog. The 2012 has the resistor that you manually change in the harness. The 2013 i believe you can change in the cluster..... What im thinking is that if i get poorer octane fuel and im not able to blend enough 110 i could install the ethanol resistor for more det protection???? Does any of that make sence. There is times where i may run out of fuel up north where there isnt a any premium fuel and all can carry is 3 gallons extra. Ive got the small 8 gallon tank on the iqr so im always out of fuel first !!
Thanks!
Thanks!
