As a matter of fact, I see airplanes falling out of the sky all the time and this is due to dry fuel.
Its funny how you mention this. Maybe not because of dry fuel, but maybe too wet, as in too much water.
"NTSB: Watered down fuel caused crash that killed 2 men"
GREEN RIVER, Emery County — A helicopter crash that killed two Utah men last year was likely caused by a number of factors, including watered down aviation fuel, according to federal investigators.
http://www.ksl.com/?sid=37067704&nid=148&fm=home_page&s_cid=toppick3
I've ran both. A 50/50 mix of avgas and 91 worked without any flaw. As for the race fuel I ran some VP 110 and some Tracktek TT111L from the Polaris shop in west both at a 25/75 mix. SO avgas cost me about 6.70 a gallon so 10 gallons of 50/50 mix would be 5 gallons = $33.50 for the avgas plus the cost of 91 (3.00?) at the pump (33.50 + 15 = 48.50) for a 10 gallon tank. The VP 110 cost me about 8.50 per gallon so 2.5 gallons of vp and 7.5 gallons of 91 =(21.25 + 22.50 = 43.75) for a 10 gallon mix. So on the average fill you save enough to buy a monster and a pack of jerky by using race fuel PLUS by using race fuel you only have to tote around half as much. These are the mixes I run. This works for 7-10 ponds of boost depending on setup.
You do realize most the time 110 will detonate the same time, or before Av... Av is usually 104 or more, where 110 can be all over the place depending how good the batch is and how old it is. No need to mix more Av if 110 works
