L
After a long pull yesterday my Pro started running like it was only on one cylinder if you blipped the throttle 10 times it would clear up run top notch. But if you let off the throttle and it got below 6000 it would run rough again. It did run out of gas the other day so I thought maybe dirt in filter, brought to dealer in town and they said it was PTO but both cylinders are dead even at 100psi cold, and 105psi both after running a few minutes I know thats a little lower than it should be. But would it run perfect at 6500-8200 if it was a bad cylinder? It didn't throw a check engine while it was a running rough. Any help would be appreciated.
