Do you have to remove the chain case to out the FTX kit in?
to install the ftx kit you only remove the front mounting bolts for the rear suspension and the 2 fender bolts.
Note: this_feature_currently_may_not_be_available_in_some_browsers
The Polaris crank does not have added internal counterweights nor the external damper-ring and same P-85 from what I saw on the HO 800-CFi on the 2015 AXYS fiche before Polaris took it down.
I wonder if the 800 HO crank (AXYS) is the same as the 600 IQ Racer crank in the 2014 IQR's??
#2205190 is the crank used in the new AXYS 800 H.O. motor
That's interesting....that's the new "pork chop" IQR crank.
Hmmmm.....
The crank with the electronic exhaust valves and oil pump make the new motor pretty darn awesome!
hmm why do you want your bars at armpit height ?I'm also digging CDK's bar setup!!
A bit shorter for me... 1" riser.
Snowest member "CDK" sled.
I've had very good luck with the U-Tech 3.8 (gloss) on prior chassis... so I saw no reason change.
I've not tried the Surefoot... but I've read good things about it on other forums.
If it works as advertised it would be worth the $75
http://betweenthelinesdesigns.com/?page_id=345
Slash,
I will only put a 1" riser on mine... compared to, what looks like, 6 or 7" riser on CDK's. (mentioned that in my post).
Shelbwyo,
Those look like RSI backcountry Bend handlebars... total of 3" rise in the bars. The RMK's (non PRO RMK's) have pivot style (EXCEPT for the 2015 SnowCheck RMK's).... I like the options that the pivot style risers offer.
Not to derail MH's thread here but aside from the crankshaft, how does electrically actuated exhaust valves & oil pump add to the "awesomeness" of the engine?
I just see those changes as the manufacture's way of attempting to comply with ever tightening emissions regulations.................
True, but think about the alternative.. A mechanical oil pump that isn't providing enough at every speed/load breakpoint or an electronic pump that engineers can use to take advantage of the modal emissions cycle snowmobiles are still using (thankfully)
