Could be many things, of coarse check the usual stuff but before throwin parts at it Check the wiring harness connector at the ecm. We spent most of a season tryin to get a buddies sled running including a new stator, coils etc. And it turned out that the connector was melted between two wires allowing them to short together. We fixed that and it's been good since
A quick test to look for electrical problems is to pull the plug on the ECU and smell it. If it smells burned you have an electrical short. The most common are the taillight wire, the handlebar warmers or the speedometer pickup. If it's not burned your problem is somewhere else.
Everything I look at as far as wiring seems to be good
Thanks
[FONT="]2 charge coils:[/FONT][FONT="]
black w/ red to green w/ red 13.6 - 20.4 ohms
brown w/ white to green w/ red 13.6 - 20.4 ohms
Unplug the main harness. Big Gray connector. These wires are going to the Stator. Not the side going to the ECU.[/FONT]
Hey, Everybody this is what I have for readings.
Charge Coil (1) 13.6-20.4 ohms black/red green/red----------82.9
Charge Coil (2) 13.6-20.4 ohms brown/white green/red------15.9
Lighting Coil 0.08-0.12 ohm yellow yellow---------------------.3
Ignition Timing Sensor 152-228 ohms green/white brown----95.6
Injection Coil 15.2-22.8 ohms blue/white blue/white----------18.4
Fuel Pump Coil 1.52-2.28 ohms orange orange----------------2.1
Unless I'm missing something I think I need a new stator.
Thanks for all the replies. I'm always open to more advice.
I didn't see this mentioned yet, but make sure the ground that hooks to the chassis on the Mag side is connected. Its a ring terminal that slides over the one of the bolts for the steering hoop with a jam nut to tighten it down. Just a quick check that eliminates that. Not sure if that would have an effect on stator readings, but worth looking at before dropping some coin on a new stator.
Looks like, at least you have found an issue most times the stator will check out with in specs. My M7 just quit over the summer, re wound stator fired right up. I used a company out of CA, I think I paid 350.00 to get it re-wound probably can find a cheaper place.
