Yeah the one between T and Q. Is it better to go through there from T or from Q? Would it be pretty much sidehilling through there?
I have made that trek several times. If I remember right it dead ends before T trail maybe a 1/2 mile (end of logging road). You then have to climb up the ridge to the South to continue. This may just be that I dropped onto that logging road that runs South of French Creek?? anyway not well marked and need to be a good rider if you run that way.
I'm not so sure you should use him for a guide.
The road he is probably speaking of is half way down the south side of the drainage and appears to stop at a clear cut but was at one time was cut all the way to Libby Flats.
