Yes, they eliminate the need for the outer ones and save weight because no added mounts needed. They also allow the track to flex more at the hyfax = easier sidehill initiation (though this effect isn't noticed as much further forward on the skid). The downside is that it prevents the use of side mounted reservoir shocks for the center shock (like the Fox I use now from Chris Burandt) as they'd hit the bogies. I've done a TON of testing and one thing you need to know is that the front bogies are absolutely necessary in order to relieve some pressure at the front of the track or you will melt hyfax at speeds over 70 mph. There is no way around that fact thus the manufacturers do this. I've also found that adding bogies to the center of the skid does nothing but add dead weight - don't bother (unless you live in the Midwest with constant low snow conditions). The manufacturers know what they're doing.
Have FUN!
G MAN
PS - You know, thinking back, a lot of riders were saying how much easier it was to sidehill/carve a 2013 because they theorized the belt drive was making up for some gyroscopic effect of the heavier chain system. I think the bogie change had a HELLUVA lot more to do with the change in handling than the belt drive ever could!
