What Belt to sheave clearance to run in an Arctic Cat 9 or 6 post clutch ?It is my opinion that a clutch should be balanced the way you plan on running it.
You can balance a clutch and then put in fly weights that are not all the same weight (which is very common) and you just created a very large unbalance in your clutch.
Also the bolt bushing and washer typically has a large amount of play (around 0.017") so when you tighten your bolt you just moved the weight of the bolt off centerline of the crank and just put unbalance back into the mix.
We like to set the belt to sheave clearance to 0.002" and put the balance into the 2/10th range or less.
A clutch with moving parts changes all the time.
So get it as close as possible and run it.
Its the best is going to be.
Remember that 7 grams of unbalance at 8000 RPM puts over 100 lbs of force on your crank every revolution.
Just something to think about.
