08 m1000 wiring issue
D
Feb 28, 2011
4
Could use a little help. Sled shut down after coming down from mtn . Couldn't get started so towed home. Got home checked the standard items, put everything back together, and it started up, but there was a puff of smoke out of the 34 pin plug in on ecu. Put dielectric on it, started it and the little puff turned into melting the red with yellow chaser wire (charge coil) . I've been reading forums, people say its a ground wire. Any help or advice would be willing excellent.
Has full slp with boondocker
Thanks
kiliki
13,213
2,398
Nampa, Idaho
you have a short in the power side.
bad servo ect
i do have an 07-08 ecu with the 09 flash for cheap 275.00 shipped.
