3 amber lights at start-up- 5 seconds. 2012 silber turbo
W
whitfork
40
7
8
41
I have a 2012 silber kit with the hose Connected to the controller. Been running fine all year. It has a indy Dan cylinder and top end kit with around 500 miles and starts and idles perfect.
Last week I started it cold and 3 amber lights lit at 123 for 5 seconds and then went to green at point 1 like normal
I only does this cold. It will now not rev up past half throttle while riding or build any boost.
I'm tearing it down to check for mechanical issues pretty soon but the season is done for me most likely due to snow.
I just want to know if this is a controller issue or if someone has a idea.
Thanks
X
XP Summit
135
Minneapolis, MN
Does your kit have the 3 bar Map sensor on it?
I have a 13 with 13 kit and I have gone through 2 of them this season. Moisture gets in there and causes it act funny.
The GM part number is 55206797
I have bought them both from the dealer locally for about $20 a piece.
When mine would go out it, on start up it would cycle the lights then go to Gr/BL and start to die. I would have to hold the throttle open to keep it running and it would run showing yellow.
Just something to look at. Good luck
