14 pro 800, all stock, 250ish miles. Bought at the end of last season and put on 100 miles. Have 5-6 rides on it this year, no issues at all. Today about 3 hours into the ride it started dropping a cylinder. First few times it acted up was after turning out from a climb, when I got back on the throttle. It did it 4-5 more times, usually after a WOT, then letting off and getting back into the throttle.
Pulled the plugs, both look fine, maybe a bit lean. Tested a few more times and now it was acting up even at 1/2-3/4 steady throttle side hilling. Just holding it steady it would drop a cylinder, keep the throttle in the same spot and 5-10 seconds later it would come back and run normal.
Pulled the hood, checked all wiring and connectors I could get to and swapped out the plugs with a "known good" used set. Headed out at that point and it never acted up for the next hour.
Any thoughts? Got it in the shop drying out tonight. Picked up 4 new plugs (dont really think thats it). Going to check all the wiring in the shop in the morning, check the ignition coils for good output, put in new plugs and try it again tomorrow.
Eric
Eric
