P
12´pro rmk 800 running on one cylinder.
hello! i have a problem with my 2012 pro rmk 800.. it´s running on one cylinder. It ran fine after the last trip i had with it, last year) So i delivered it to a polaris dealer to check what the problem was. They said that the compression was low.. 116psi, and that it SHOULD be around 159psi?? is that true? anyways, i changed pistons, and checked compression,All good.. Fired straight up after 3 pulls.. Sounded like it was running fine!
I tested it for about 5 minutes that night, and it all seemed good. The day after, the problem was back.. Started it up, and it was running on one cylinder again. Checked compression, spark, fresh fuel. Didn't help.
Its like it wants to run on both just when I'm starting, but after one sec its running like ****. Anyways its seems like the other cylinder "kicks in" at around 5000rpm, and then it runs fine. But as soon as rpm is under 5000. Its running one one again.. i have only seen the check engine lamp for a couple of seconds. The codes was:
-"trottle release signal, trottle stuck",
-"trottle position sensor, abnormal rate of change"
but after a restart, it never came up any more lamps.
Here is a video of the problem: https://www.youtube.com/watch?v=bas-ynmRD6s&list=UUkGdL0agA8TEJUmye3fuRIQ&index=1 bad quality video, but you can hear the pro side cylinder kicks in at about 5000rpm.
hoping you guys could help me
