IceAge PRO MOTION... MY INSTALL AND SOME QUICK THOUGHTS
mountainhorse
18,606
11,814
West Coast
www.laketahoeconcours.com
Well packaged and arrived quickly from IceAge.
attachment.php
Very nice fit and finish. The machining quality and finishing looks top notch.
attachment.php
This photo shows the ball-joint (spherical bearing) that allows the rails to flex.
attachment.php
The test subject... 2015 PRO RMK LE 155" suspension.
attachment.php
All the tools I used for the install except for a 3/8"-drive torque wrench and a grease gun.
attachment.php
Before the stock scissor removal.
attachment.php
Using 13mm socket and 13mm box wrench, the upper pivot bolt pulls easily.
With the skid out of the sled, it allowed me to simply swing it up and out of the way...If it were in the sled... a simple string or wire would keep it up and out of the way.
attachment.php
I applied a thin smear of grease on the shaft before the sleeves went on for corrosion protection.
attachment.php
attachment.php
IceAge provides high quality bolts that already have locking compound on them.
attachment.php
Installed onto the rails, torqued to 50ft lbs (600 in lbs)
attachment.php
Pre-Greased and then slide the provided upper shaft into place.
Making sure not to get grease into the threads.
attachment.php
Bolted into place on the upper arm using the provided flat head hex-socket cap screws... I used some blue Loctite on the threads and then torqued to the specified 25 ft lbs. (300 in lbs)
Gave it a few pumps of the CV-2 Redline grease while on the bench.
attachment.php
Finished with install...Waiting for the sled to be finished.
attachment.php
attachment.php
1B AS ARRIVED.jpg 1B2 AS ARRIVED.jpg 1C Showing flex.jpg C Tools.jpg B Original.jpg D original 2.jpg E Lube shaft.jpg F SLEEVES ON .jpg F2 BOLT.jpg G INSTALLED PRO MOTION .jpg H LOWER SHAFT GREASED.jpg I INSTALLED.jpg J FINISHED 1.jpg K FINISHED 2.jpg A 2015 PRO RMK LE Skid.jpg
mountainhorse
18,606
11,814
West Coast
The instructions are super simple and straightforward.
My install took a total of 30 minutes including taking photos.
It would take about the same amount of time in the sled.
At first glance you would think that that the shock and arm needs to pivot to allow for movement.
It took me a few moments to wrap my head around it at first too.
BUT...
The front and rear torque arms remain, as stock, secured to the tunnel...so those do not move any differently than the stock install.
What DOES pivot is the PRO-MOTION kit itself...This pivot of the lower PRO-MOTION scissor allow the rails to flex from side to side by the amount provided between the motion-stops built into the CNC machined scissor block.
I'm praying for snow now so that I can get some time on it!!
P
Jun 29, 2008
361
60
Freeborn, MN
Im considering this for my sled this year. What I'm really struggling with is how can only the rear mounting to the rails have a flex point and not the front? Won't that tweek the rails if the back is pivoting but the front mounting point is not? Maybe I'm overthinking this too.
Chad
mountainhorse
18,606
11,814
West Coast
Chad... I see where you're coming from.
And to be fair... I've not run it yet, though to me, the concept is solid... the rails should have no issues with flexing... Time will tell.
9
907assault
Nov 26, 2011
93
29
18
Kenai Peninsula, AK
What I can't wrap my head around is......
Doesn't a stiff / rigid skid sidehill better? It has a cutting edge to pivot on. To me, when I picture it in my brain, on a sidehill a pivoting portion of the skid would always be wanting to tilt downhill. So you'd be working the pivot and cutting in.
Maybe thats just me, or I'm thinking this thing pivots more than it actually does. Even so, I can't see it being a benefit. Just seems like a rigid chassis / skid is the way to go if you are a rider that "feels" everything while in technical riding siutations like myself.
sledneck_03
2,326
613
Saskatoon, SK
Maybe it works like a tire with less air pressure. Like a high pressure narrow tire on a bike on angled hardpack will slide down the face with the bike vertical. A wide less pressure tire conforms to the surface, sticks and gives you way more traction... Could work that way. So the track angling more parallel with the hill on a side hill would pack the snow perpendicular with the hill vs packing it down the slope? Mmmm no idea. Polaris has a picture on their website that shows that the bendy xm is a disadvantage over the pro, could just be marketing bull too.
#canadastrong
89sandman
4,897
2,072
southern oregon
Nice looking piece, know it works for the xp chassis, would be interesting if it made the pro even easier to carve. Back in the 90's everyone thought the stuff then was as good as it gets and look at what total pos's those sleds are now. Someone has to think out of the box or we'd all still be riding 500+ pound tanks, no offense yami riders;)
P
Jun 29, 2008
361
60
Freeborn, MN
I'm just thinking out loud, thats what is so great about a forum. But before guys were adding rail stiffners to avoid the flexing, and even on IceAges website they say their X-Brace they have will affect the performance of the Pro-Motion attachment. If the Pro-Motion needs the rails to flex to work correctly, then.....my head is going in circles. The Pro-Motion pictures on the website show the skid sitting flat on a bench and the rear pivoting back and forth without the front end of the skid leaving the flat bench, something has to be giving somewhere. Iceage is king of rails, so I'm sure the testing has been done, I'm just a guy with a sled LOL
X
XP Summit
135
Minneapolis, MN
I bought one and I am excited to try it out. I do believe it will make the sled handle a little different than we are used to, but I am fine with that as my style of riding is a little more finesse vs aggressive. I personally think the benefits of getting the weight to transfer with less effort, in most backcounty riding conditions, will be more beneficial than potentially some awkward track angles. (still trying to wrap my head around that). I don't believe pivoting arm will be for everyone, at least not yet. There are still a lot of benefits for having the entire rear skid solid.
P
Jun 29, 2008
361
60
Freeborn, MN
Yes, thats what I was getting at, glad I wasn't off my rocker. Hurry up and get some time on that sled so I can determine whether to order one for my trip at the end of January or not!!
Chad
winter brew
4,332
LakeTapps, Wa.
Now they need to make a front arm that' s split (like the Doo) so the arm or rails don't fatigue. if it's the rails "flexing", the force required for them to flex is feeding through the front arm. If it's the front arm flexing, how many times will it flex?
Sorry....destructive testing for a living, I watch aluminum stuff fatigue and break on a regular basis so I'm always looking for the weak link. :face-icon-small-hap.
A
Apr 30, 2008
391
157
Anch, AK
10^6 cycles best guess design number.
No different than pounding down a trail or jumping. Everything flexes.
N
nort10
77
69
18
41
Lolo, MT
Anybody get any seat time on one of these yet?
I have roughly 130 miles on mine.....the first 90 to 100 miles were road miles but with 1' to 2' of powder. I added a number of things to my sled this year (Dynoport pipe & can, V-force 3R reeds, Walker Evan piggyback shocks in the front, Dan Adams seat, and the Pro-motion) so I needed to tune and get my sled dialed in. The first two days were just tuning, getting the clutching dialed in on the road and in some meadows. The last day I was more focused on shocks and the pro-motion. I went back and forth from my sled (2014 Pro RMK 163) & my friends sled (2014 XM 163) so a pretty good comparison. I could actually get on some steep side hills and so far I haven't noticed any washing out from the pro-motion. I'm thinking the lower pivot point (1" off the track with the pro-motion) compared to the (5" off the track with the t-motion) feels like it holds a way better side hill. They both roll over really nice (T-motion & Pro-motion). The pro-motion makes it so much easier to initiate now for the Pro than it did before. I think it is going to make a rider conserve energy through out the day for when you really need to use it. Time will tell with more steep side hills and seat time because if it washes out where it didn't before it will come off my sled!! Right now I'm really impressed with it though!!!!
