AFR bung for Nytro
CF7SP
139
24
Rhinelander, WI
I'm in the process of installing an AFR gauge and was confirming the location of the oxygen sensor. The directions state 300-500mm from piston skirt and where the x is marked is more like 600-650mm. Is that an ok location? Thanks in advance!
I
inspector01
379
297
MN
Yea, thats fine. You'll want it after the collector so you are reading an average across all cylinders instead of just one.
TRUEBLUEMAX
751
280
Hooper, Utah
I have a turbo and the turbo manufacturer installed it after the turbo and it didn't read well. I put it where you marked and it works great.
Givemeaboost
157
Great Falls, MT
I would think that you would want it farther to the left where the pipe is bigger in diameter so it doesn't impede the flow as much.
Ken.......
