I am selling my 3 babies.
'03 Summit 159x15x2 with an rk tec 827 big bore kit. DPM. Rev carbs. Boyeson rage cages. Mesh hood. Simmons skis. Skis plate. Narrowed front end. Titanium bolts in front. Hyme ends on radius rods. Aftermarket pipe trailing arms. 1" post forward spacer. RER reverse. 8" billet big wheels. Lefty throttle. 8" bar riser. Digital tach. Digital egt. Mod seat. Runs amazing! Had out to Walden this year. 4 trips on big bore kit approximately 75 mile trips. 1500 miles on bottom end.
'02 Summit 151x16x2.25 hill climb track 800. DPM. Dual ring Pistons. Can. Rev carbs. Boyeson rage cages. Offset keel skis. Skid plate. HPG Rev shocks. Narrowed up front end with hyme radius rod ends. Aftermarket pipe trailing arms. Billet 8" big wheel kit. Goldfinger lefty throttle. 8" bar riser. Wired for heated handlebar bag. Mod high rise seat with storage. LED taillight. 1575 total miles. 250 miles on Pistons.
'01 Summit 151x16x2. 800. DPM. Rev reeds and spacers. Narrowed up front end with hyme end radius rods. Top shock mounts lowered for taller stance. Offset keel skis. Custom drop brackets and running boards. Custom mod highrise seat. '03 tail light assembly. Inside rear wheels. 6" bar riser+2" pivot. 1" post forward kit. Can. 4918 miles on chasis. 400 miles on new crank. 1500 miles on top end.
Probably forgetting a lot. Ran these for quite a while. Good compression. You won't be disappointed. Can email pics it's easier.
$2750 for '03
$2500 for '02
$2250 for '01
Might cut a deal on the whole package. Thanks
Josh
$2750 for '03
$2500 for '02
$2250 for '01
Josh
