http://www.snowest.com/snowmobile-news/display.cfm?ID=2520
Yamaha Announces Major Options for 2011 Nytro MTX
Yamaha-exclusive 180-hp Push Turbo, MPI Supercharger systems
Yamaha announced at a press conference today at Hay Days exclusive power options for 2011 Yamaha Nytro MTX models.
A Push Turbo and MPI Supercharger system will be available through Yamaha dealers later this fall. Both systems will produce 180 horsepower and feature factory presets that eliminate user tuning.
Both the Push Turbo system and MPI Supercharger system are designed for 6,000-ft and higher elevation applications.
Both systems are priced at under $4,000 USD.
Yamaha also announced an optional rear suspension kit for the Nytro MTX that reduces the weight by approx. 25 pounds.
More to come...
UPDATE
Here's the details:
FX Nytro MTX Turbo
By Push Turbo
Distributed exclusively by Yamaha Genuine Parts & Accessories
MSRP: $3,995
YPAD Part Number: SMA-TURBO-00-00
Fits 2008-2011 FX Nytro MTX Models
Easy installation, only cutting required is a 2-1/4 in hole for charge tube. Turbo comes pre-assembled and mounts above tunnel in place of factory exhaust muffler.
Uses OEM style wiring connectors
180 HP on premium pump gas
8 psi boost (non-adjustable)
1-year warranty (through Push Turbo)
Available exclusively at Yamaha dealerships
For use above 6,000 ft elevation
"The Push Turbo kit is designed only for operation at elevations above 6000 feet. While installation of this kit will not 'void' your snowmobile's warranty, specific failures determined by Yamaha to have resulted from installation of kit components or other modifications may not be covered by the Yamaha limited warranty or extended service coverage." -Official release statement.
FX Nytro MTX Supercharger
by Mountain Performance Inc.
MSRP: $3,995
YPAD Part Number: SMA-SUPER-00-00
Fits 2008-2011 FX Nytro MTX models
Uses OEM Style wiring connectors
Uses stock exhaust
6 psi boost (non adjustable)
Features fuel-only GEMS control module that is non-adjustable
1-year warranty (through MPI)
"The MPI Supercharger kit is designed only for operation at elevations above 6000 feet. While installation of this kit will not 'void' your snowmobile's warranty, specific failures determined by Yamaha to have resulted from installation of kit components or other modifications may not be covered by the Yamaha limited warranty or extended service coverage." -Official release statement.
Photos coming soon...
More to come...
UPDATE
Here's the details:
FX Nytro MTX Turbo
By Push Turbo
MSRP: $3,995
MSRP: $3,995
Uses stock exhaust
