R
Putting together a turbo kit, and I've been brainstorming ways to lube a ball bearing garrett turbo without using the traditional electric pump and tank method.
The oil injection pump has two bottom fittings that are teed together immediately after the pump as seen in the picture
What would stop a guy from removing the tee fitting, and using one of the outlets to feed the turbo? Doing this would allow me to continue to feed all the case fittings as well as the turbo. For a oil return from the turbo I could just use a small vented oil catch can with a drain valve that I would then have to empty every so often.
Could it really be this simple or am I missing something? I don't really like the idea of feeding the return into the turbo inlet like the MTNTK kits do, but that's just my opinion.
