I have to "calibrate" my Boonybox to idle and WFO (it's #'s aren't in volts). Doesn't mean it is "calibrating" to the correct volts.
Maybe the volts shown though the screen are correct, maybe not.
The reason I question this is I was told in '13 the PCV doesn't show the correct #'s by the supplier of the PCV and kit included (I respect their R&D) and they gave me their reason why.
So I've used it as a reference point (reason to sync PCV) to see if things have changed over the years but have never used it as an absolute to reset-test TPS.
Three years and no issues with the way it came from the factory but VR3's have changed something and it isn't just idle. I don't have a stock sled and am trying to eliminate things one at a time.
Some posts in the VR3 thread have made me want to go through the whole TPS process just to eliminate that first.
I have a PCV, battery, lap-top. I don't have a calibrated tester or a Poo machine.
So,,, has anyone compared voltage readings through the PCV with those from a well calibrated tester and meter? Or, even better, a Poo machine?
