Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 09-17-2012, 07:58 PM
izzni's Avatar
izzni izzni is online now
Currently: Improving the NS1 Gauge System
izzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond repute
Default Reinstalling the Skid Frame
So I had my skid frame out to have the shocks rebuilt, replace a broken weld on an arm, replace the rails with the front shock mount had screwed up, and repaint the other suspension components so that it looks pretty again
Long story short, due to a cluster **** getting my shocks rebuilt and spacers put in the front (I mailed 6 shocks and received 5 back and had to buy two new shocks since I couldn't get just one for less than 2 ) I'm not confident that the guy who put the spacers in the front shocks (of which one went missing) didn't put the spacer in the rear shock I sent out too.
So here are my questions:
1) I've got the skid partially in, but I forgot to grind the rivets (drilled the two new holes already). I've noticed that the front bolt holes are like 4 inches in front of their holes at the moment. I'm used to skids being a pain in the *** to install though, so this itself isn't alarming. Should I be alarmed? Is there a hint to install the skid easily (for example, removing the springs? Wait a minute...the shocks are air shocks... :P)
2) What is the center to center distance of the rear shock in the skid frame?
Thanks,
Izzni
Rate this post: Yes | No
  #2
Old 09-17-2012, 08:53 PM
ACMtnCat ACMtnCat is offline
Currently: Hold'n on to Black Metal!
ACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond repute
Default
When I remove the skid I let the air out of the rear float first. Then when installing the skid I put the rear arm bolts in first then i can move the skid around easily to line the front bolts up.
Your rear scissor is likely causing your miss alignment.
The Following User Says Thank You to ACMtnCat For This Useful Post:
izzni (09-17-2012)
  #3
Old 09-17-2012, 11:18 PM
izzni's Avatar
Default
Yeah, I just needed to lift the back of the sled off the ground. Do that and with only relatively minor hanking you can get the front bolts in
  #4
Old 09-17-2012, 11:40 PM
RACINSTATION's Avatar
RACINSTATION RACINSTATION is online now
Currently: Getting Excited for the 2018 CAT!
RACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond repute
Default
I have found that the easiest way to install a rear skid by myself is to lay out a clean cover and roll the sled over onto its side (protected from the floor by the cover). Set the front arm into place and bolt it in, roll the sled over to the other side and put the other front arm bolt in (not tight). Then get a prybar with a rag on it so you don't scratch things up and put the rear pivot bolts into place. For some reason it is significantly easier to install this way.
__________________
The Racin Station
60 South 1st Street Driggs, Idaho 83422
Ph: 208-354-2777 E-Mail: racinstation@hotmail.com
The Racin Station is your TURBO MOD HEADQUARTERS
for Arctic Cat Proclimb 8000/1100 and Yamaha Vipers and Sidewinders!
TIMBERSLED FULL LINE DEALER!!!
Proclimb Carbon Fiber Vents
Your MDS weight headquarters
Team ProClimb secondary complete setups ready!
Reman M6,M7,M8 and M1000 cylinders in stock.
Jaws M8 Singles for the 2012-2017 in stock!
Jacobsen Rollover valves in stock for M1100Turbo and Viper/M7000!!
Camoplast 3" and 3.2" 174, 162 and 156 x15 tracks on hand now
  #5
Old 09-18-2012, 12:38 AM
Default
Quote:
I'll race you! Pull and reinstall skid. If i win i get a 3" CE for cost. You win you get two wraps for cost. Lol
  #6
Old 09-18-2012, 07:13 AM
HOOCH256 HOOCH256 is offline
Currently: 2012 ProClimb CPC stage II
HOOCH256 has a reputation beyond reputeHOOCH256 has a reputation beyond reputeHOOCH256 has a reputation beyond reputeHOOCH256 has a reputation beyond reputeHOOCH256 has a reputation beyond reputeHOOCH256 has a reputation beyond reputeHOOCH256 has a reputation beyond reputeHOOCH256 has a reputation beyond reputeHOOCH256 has a reputation beyond reputeHOOCH256 has a reputation beyond reputeHOOCH256 has a reputation beyond repute
Default
I'd pay to see that race!!!!
Sent from my super duper sweet iPhone using Tapatalk when I should be doing something productive!
  #7
Old 09-18-2012, 10:04 AM
Default
There you go! We could sell tickets and both get a track and a wrap!!
__________________
The Racin Station
  #8
Old 09-18-2012, 12:33 PM
Sled208's Avatar
Sled208 Sled208 is offline
Currently: powder bound
Sled208 has a reputation beyond reputeSled208 has a reputation beyond reputeSled208 has a reputation beyond reputeSled208 has a reputation beyond reputeSled208 has a reputation beyond reputeSled208 has a reputation beyond reputeSled208 has a reputation beyond reputeSled208 has a reputation beyond reputeSled208 has a reputation beyond reputeSled208 has a reputation beyond reputeSled208 has a reputation beyond repute
Default
I switch tracks between mountain riding and going up north and I switched my track 5 times last year on my 2012 High Country. I have a chain around my rafter in my garage and I lift the rear of the sled off the ground and hang it by a cam buckle tie down strap so I can easily adjust the height. Once you get the front bolts in, the rear bolts line up VERY easily on these sleds. There's some movement in the suspension and I've been able to easily pull it into place with my hands.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Reinstalling M8 rear skid, help needed Thread Starter — mustard73 Forum — Arctic Cat: M Series Replies — 10 Last Post — 12-06-2011 01:45 PM
Thread — WTB m series skid frame 09 or 2010 Thread Starter — brickhead Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 11-02-2010 11:37 PM
Thread — Skid frame???? Thread Starter — jesse055617 Forum — Arctic Cat: 1M Replies — 3 Last Post — 11-18-2009 04:15 PM
Thread — skid frame Thread Starter — bgraff1 Forum — Polaris: GEN 2 Replies — 1 Last Post — 10-26-2009 08:42 PM
Thread — mountain addiction skid,frame,complete. Thread Starter — richeh123 Forum — Suspension/Shocks (Swapmeet) Replies — 7 Last Post — 01-08-2008 03:19 PM
